Author Topic: Awesome magnetic robots  (Read 5135 times)
Online mikeselectricstuffTopic starter
    • Mike's Electric Stuff
« on: April 17, 2014, 10:06:29 am »
This is the coolest thing I've seen in a long time...
http://www.wired.co.uk/news/archive/2014-04/16/magnetic-microrobot-swarms
Would be fun to figure out how this works - couldn't immediately find the patent mentioned on the SRI site
Observations :
Robots look like they may be clusters of small, presumably neodymium magnets - especially in the first pick/place demo
The flex demo only moves in one axis, and has few connections
There is what looks like metal foil over the PCBs - is this for magnetic reasons, friction reduction or both?
The rigid PCB is sitting on a thick metal plate - magnetic, heatsinking or both?
The PCN top layer appears to have fairly long tracks - far too long for localised control, presumably acting in conjunction with a finer-grained structure on the underside.
I don't know enough about magnetism to know the significance of the "diamagnetic" stuff - I've seen diamagnetic levitation so maybe helps to reduce friction?
I wonder if maybe a lot of the movement actually is along predefined routes in the PCB, as opposed to being fully x/y capable - some of the demos seem to involve unnecessary movements, ane the very first demo seems to have a fairly uninteresting motion route
What really puzzles me is how they get the rotation
« Last Edit: April 17, 2014, 10:26:58 am by mikeselectricstuff »
Day Job: Mostly LEDs
Offline tom66
Re: Awesome magnetic robots
« Reply #1 on: April 17, 2014, 11:24:22 am »
One of the ways you could do this is by having the robot in a continuously unfavourable position (i.e. when rotated it wants to snap back.) This would be generated by an opposing magnetic field holding each robot in the unfavourable position. Rotation is then slowly allowing the robot to go back to the position it wants to (under no power.)
« Reply #2 on: April 17, 2014, 11:54:49 am »
How hard can it be...?
Offline dr.diesel
« Reply #3 on: April 17, 2014, 12:02:53 pm »
Agreed, that is awesome,  :-+
How long till there are bought by Googlenet?
Offline Dave Turner
« Reply #4 on: April 17, 2014, 04:22:57 pm »
Wow!
I wonder how small they could go.
Offline Christe4nM
« Reply #5 on: April 17, 2014, 05:03:02 pm »
Definitely! Absolutely cool!
Offline Kevin.D
« Reply #6 on: June 07, 2014, 03:08:19 pm »
Someones done a  2 D automated movement  version using the same idea that Mike used .
Offline Rory
« Reply #7 on: June 07, 2014, 03:22:57 pm »
Looks to me like someone has a magnet under the table.
Offline miguelvp
« Reply #8 on: June 07, 2014, 09:14:16 pm »
If you look at his project link, it looks legit:
http://spritesmods.com/?art=magnmicrobots
« Reply #9 on: June 07, 2014, 10:28:36 pm »
Lots of info in the patent  :
https://docs.google.com/viewer?url=patentimages.storage.googleapis.com/pdfs/US8593016.pdf
Couple of interesting things on a quick skim - use of a diamagnetic layer to reduce friction, and conductive (presumably copper) for damping via eddy-currents.
I wonder if bismuth foil would be diamagnetic enough - probably easier then getting a big sheet of pyrolytic graphite.
