Touchy, eh? I'm just pointing out that the simplest multimeter probes from your favorite supplier are around $19. Not exactly a bargain. And you still have to cut away the shroud/shield.
Do you have associations here? Just asking.
I thought we were talking of test leads?
No associations and I mentioned 3 different products, including a bargain-basement priced one, that would solve the OPs problem and still prevent the safety issue of having an energized exposed lead if the plug should slide out of the meter.
But as to the cost of Probemaster, $19 gets you a very nice set of sharp gold-plated soft-handled probes with silicon leads of 24, 36 or 48 inch length and the aforementioned retractable plugs (see 8018S) from a company that provides support and a non-fake CAT III/IV rating. I don't see that as exorbitant.
