My whole life, from a little kid to now as a professional engineer, I’ve found op-amps to exist under their own mysterious rules. As a kid I’d build circuits out of radio shack’s electronics learning lab and I’d of course make mistakes, fix them, and once fixed have a circuit do w/e thing it was supposed to do.. all unless it had op-amps in the design. If Op-Amps were involved the circuit
may work, and if I was lucky enough that it did great it would continue too. But if the circuit did not however work right off the bat, well who knows what magic would lead it to not, often only disassembling the circuit entirely and building from scratch again would resolve the problem, unlike the other circuits I just didn’t have any intuition as to what could be worng. I was just a kid though and obviously might just be unable to discover the error I made.
Fast forward to college however and this problem still would crop up, I would do undergrad research in active filtering and for the most part my simulations would work irl and then suddenly not. A wire would be misplaced in a RC filter somewhere and now the Op-amp is out to lunch, can I fix it? Somehow not, was the amp broken? Nope, building it back from scratch and it all works again.
Later I’d take a known good design that simulated properly, worked on a bread board/ prototype board and fab a PCB – that PCB has never worked and why remains a mystery as to why, I’ve triple checked the schematic, the gerber and ult. just ohmed out every pad on the PCB
and it all checks out… but never the less doesn’t work the OP amps do literally nothing I get no signal out from any part of the circuit, and eventually they’d permanently break, why who can know lol it’s not like there are any obvious shorts or errant voltages.
Even now in my profession this sorta thing causes problems, recently needed to design a Schmidt trigger for a prototype system, works great in LTspice – on the board doesn't work
, either screams at me or latches to one rail or another… even a simple comparator somehow eludes expected behavior sometimes, eventually I'll get it all to work but why? Who knows?
Wondering if anyone else out there has had a similar experience with Op-amp "magic"
