I've built a couple of the Wireless World receivers using the 1496 mixer.
The first one sort of worked and needed much modification.
Then MSF moved from Rugby to Anthorn and lo! the signal level changed & it didn't work.
After much hacking about another version with added 60kHz amplification did deign to function, during which I was eventually reminded that bandpass tranformers need a coupling coefficient between the coils of a good deal less than one.
I bought all the ics for the original fast decoder and they've remained unused for the last 40 years.
I used a pic16f84 to decode the slow transmission, one of which uses a 16x2 LCD to display the time, the other displaying it as binary digits (well I was bored in work).
The output of the 1496 never seemed to correspond very well with the waveforms in the article & the comparator eventually became a floating comparator which did work reasonably enough.
Another receiver was the Rewbichron module from Ambit, of which I have two examples, neither of which ever seemed to do anything sensible at all.
Further potching led to a receiver using a PLL tone decoder that seems to work adequately.
I miss Wireless World, it was downhill all the way after 2005, the issues for 2006 & 2007 met the recycling last year when I determined there was nothing of any interest whatsoever in them.
