Author Topic: OP-amp's pin 1 (OPA2365)  (Read 233 times)
Offline Axk
  • Country: by
« on: October 12, 2019, 02:33:49 pm »
http://www.ti.com/lit/ds/symlink/opa2365.pdf
The actual package's photos are attached.
I doesn't have the dot or the round cutout.
Am I correct that the vertical line is marking the cutout side and pin 1 is on the bottom left in my top view photo?
It is kind of confirmed by the chamfer on the bottom corresponding to the drawing in the datasheet, but I'm not 100% sure.
Offline JackJones
Re: OP-amp's pin 1 (OPA2365)
« Reply #1 on: October 12, 2019, 02:39:33 pm »
Is one side of the package cut/chamfered at 45 degrees? It's a bit hard to tell from the pictures, but it looks like from the pictures that the bottom side of the text is chamfered at 45 degrees. It's not very common to see and probabably not general knowledge but the chamfered side marks the pin 1 location.
Edit: Duh, you did mention the chamfer. It does indeed mark the pin location.
« Last Edit: October 12, 2019, 02:41:04 pm by JackJones »
The following users thanked this post: Axk
Online SiliconWizard
« Reply #2 on: October 12, 2019, 02:41:40 pm »
Yes and yes. The bottom side (on your pic) is definitely chamfered.
Online RandallMcRee
« Reply #3 on: October 12, 2019, 04:01:32 pm »
Right--its in the datasheet that you were pointing to...see this page:
