Dave-
Solar panel efficiency is unimportant unless you have limited roof space or you are mounting on a tracker or a pole mount in which space is at a premium. The efficiency of all modern, commercial solar panels are within a few percentage points - since you look to have a pretty large roof area to work with efficiency should not be a deciding factor.
Similarly - all the large solar panel manufacturer's warranties are pretty similar these days - 10 yrs workmanship, 25 yrs performance with a derating for age. It's true that many solar panel companies have gone belly up so the stability of the company for warranty purposes might be something to consider - but the truth is that solar panels rarely fail. In the rare case that their performance falls out of spec - this will likely show itself right away.
Mono versus Poly crystalline - also a non issue. Mono panels are generally slightly more efficient (non issue - see above) but any other differences (sunny vs cloudy performance) is minimal.
Bottom line is that solar panels have become a commodity product and all the large (mostly Chinese) manufacturers produce similar quality panels - despite the marketing hype. There surely are some cut rate - poor quality panels being made somewhere but it's unlikely any professional installer is going to use them. Trina solar and LG are going to be similar quality.
With similar quality and warranties - the solar panel companies are all competing on price (and marketing hype) - with large quantities now available to consumers here it US at less than $1.00/watt.
Inverter quality and features do vary. You can't go wrong with SMA. High quality (German engineering and all) - but you'll pay for it.
What IS very important for someone like yourself getting a professionally installed grid-tied system is the quality of the installation - ESPECIALLY the mounting to the roof. Poor workmanship there will cause problems- roof leakes, damage during wind storms, etc.
Also - one factor that has been prove to have fairly large effect on performance in warm climates is the distance off of the roof that the panels are mounted. Temperature has large effects on panel perfomance and without adequate ventilation under the panels performance will suffer.
So when deciding between installations - I would focus on the reputation of the installers, how they physically mount to your roof and how high of standoffs they use to get the panels up to ensure adequate ventilation.
A couple of great rescources:
PV Watts2 Calculator lets you model the solar array output at your location using various parameters.
The
NAWS forum is the premier forum for solar electric and other renewable energy.
Good luck.
