Author Topic: Optics lens design sw recommendation  (Read 493 times)
Offline pisoiuTopic starter
« on: June 16, 2020, 06:35:20 pm »
Optics is not my strong point  :-// . I understand basic principles but that's about it. However, I need to design a lens system and I have nobody I could ask to do that for me.
Basically I have a laser diode and I need to pull out from it a parallel beam of a certain dimension. For that, I need to use a convex lens or an assembly of concave and convex lens, because I have some size restraints.
Can anyone recommend me a free application for basic optics design in which I can enter some lens parameters and see how the light propagates? I do not need complex things, no coatings, I work with single wavelenght, etc. The goal is to get parameters of the lens I need, so I can send them to chinese manufacturers to make them.
Thanks.
« Last Edit: June 16, 2020, 06:38:37 pm by pisoiu »
Re: Optics lens design sw recommendation
« Reply #1 on: June 16, 2020, 09:20:00 pm »
Offline jmelson
« Reply #2 on: June 16, 2020, 10:00:16 pm »
Generally, a sphere lens is used for this, almost touching the front of the laser module.  You can get 2mm and 3mm sphere lenses.
Jon
The following users thanked this post: pisoiu
