Author Topic: orbital maintence tools? a threat?  (Read 3593 times)
Online coppercone2Topic starter
« on: December 21, 2023, 08:28:16 pm »
I saw some news article about the threats posed by Chinese orbital maintenance tools that can be misused.
Am I the only one that thinks that its a great idea to develop the tech to refuel and repair satellites? I wanted this tech for years, it seems like what the beginning of the space age actually looks like, that you can sustain small infrastructure in space on maintenance contracts from contractor companies and stuff, instead of basically being tied to a 'trucking company (heavy launch)' for the entire product life cycle.
IMO even something as simple as a satellite being able to have its card swapped in space by a robot means that the cost of sat development went way down, much like computers. You can put more ram, a new monitor, better sensors... extends the life of a computer drastically.... and eventually when the repairs get good enough (space soldering) you could even get away with doing less tests on issues that can likely be fixed in orbit by repair/upgrade/maintenance bots.
I hope the DoD does not stunt development of this technology but some how works to improve warning satellite security and stuff so it can coexist.
Because IMO, its really starting to feel like its the begining of the real space age where there is potential for cheap applicability to space projects.
I am imagining essentially floating PC's in space with generic inputs that can be retrofitted with various hardware, even possibly on a space rental basis, developed at a later time. Then you only have 1 heavy launch for the power system and then just robots or possibly space workers to plug in cards. And you don't have power constraints of things like cube sats, its more like you get access to a large power source on board for your card.
and it seems like there will be less space debris this way, since project life is extended, and the 'chassis' can be reused. Space Milkshake comes to mind
« Last Edit: December 21, 2023, 08:33:04 pm by coppercone2 »
Offline u666sa
  • Country: ru
Re: orbital maintence tools? a threat?
« Reply #1 on: December 21, 2023, 08:33:00 pm »
Nah. Because tech in 5 years, gets old. We talking about space age tech. Spy images and stuff. So it's pointless to sustain it, really. In 5 years your new satellite is old, in 10 years it is obsolete. Space trash really.
« Reply #2 on: December 21, 2023, 08:33:47 pm »
why. You could put a different low power card on it to use degraded solar panels. Efficiency improves. I think its a total game changer
its literary repurposing a self powered mainframe (in the sense of a HP modular system) that has communication and power generation + chassis, just floating around in space. if its built right
Offline CatalinaWOW
« Reply #3 on: December 21, 2023, 08:52:40 pm »
I like the old quote, usually attributed to the American baseball player Yogi Bera. "Predictions are hard, especially about the future."
Old technology makes sense in space for a couple of reasons.  First, since it is really expensive to put something up there, it takes a lot of functionality improvement to make the cost of replacement worth it.  Second, the environment favors older technology.  As gate sizes get smaller sensitivity to radiation goes up.  A lot.
But the cost of putting stuff in space is coming down.  If Musk succeeds with his Starship, it will come down a lot.  Changing the calculations in many ways.
Doing in orbit maintenance may make sense for economic reasons, but as with any technology can be applied for good or evil.  Two groups want to limit this technology - those who think they have a big lead, and those who think they are far behind. Those seeking the economic opportunity will be for, and certainly there is overlap in those categories.   I certainly can't predict how this will play out.
All of this plays into the background of limiting how much stuff is randomly floating around out there.  If we can't control the collisions the whole point will be moot.
Offline u666sa
  • Country: ru
« Reply #4 on: December 21, 2023, 08:56:33 pm »
Tech goes like this.
Space -> Military -> Consumer
It's a time process. Thing that are in space right now will soon be mainstream military, and then later mainstream consumer.
You talking about changing modules, most likely fuel and some other low stuff upgrades. I guess okay for consumer grade single purpose satellites. But for spy or weapon, like nuclear or kinetic weapon, no. I don't think this is useful for dual use satellites. That's my unprofessional opinion.
I will go further. Elon Musk right now doing reusable self landing boosters. Well, Soviet Union did those in 70s and deemed them too expensive and not useful. It is old tech. What Elon Musk doing now in consumer segment is 20 + 30 = 50 years old. Soviet Union pioneered this tech and scrapped it. Just think about the technology in terms of time. You have to feel it and breath it in. What we have there up there now is 40+ years ahead of what we will have in consumer segment down here. It makes absolutely no sense to keep old crap in orbit.
Offline Kim Christensen
« Reply #5 on: December 21, 2023, 09:13:41 pm »
The problem with launching a repair mission from Earth's surface is that it takes a lot of deltaV (Fuel) to reach orbit and rendezvous with the target satellite to be repaired. So much so, that for small satellites, it's just as efficient to send a new one because the robot + parts payload mass would be comparable. It can work for fixing large expensive/massive sats, like the Hubble repair missions.
It could possibly work if you had a large number of expensive satellites that all used the same universal parts. Then you could park a "parts depot" and repair robot in a similar orbit with a bunch of spares. But that would have problems of it's own due to the difficulty in keeping propellant from slowly leaking away and the limited number of orbital changes. (Costing DeltaV/Fuel every time you rendezvous with a different sat) Plus, space is a harsh environment and the spares would slowly degrade from radiation, etc.
The following users thanked this post: u666sa
« Reply #6 on: December 21, 2023, 09:43:47 pm »
well the point is the chinese are looking into it right now and the US goverment is scared. So it must be feasible to launch cheap maintenance missions.
Offline u666sa
  • Country: ru
« Reply #7 on: December 21, 2023, 10:06:03 pm »
The U.S. has this tech. There is the narrative yea. But it's all political. The distance between political talk and what actually is feasible or been done is far, far in between.
Online abeyer
« Reply #8 on: December 21, 2023, 10:07:57 pm »
The US government was terrified of the "Bomber Gap" and then the "Missle Gap" too... (or at least it benefited them to act like they were) so it's not clear that public statements to that effect have any real reflection on the underlying truth/feasibility of the issue.
Online SiliconWizard
« Reply #9 on: December 21, 2023, 10:46:44 pm »
 |O
Online tszaboo
« Reply #10 on: December 21, 2023, 10:56:51 pm »
I tried doing this in KSP, and it wasn't feasible there. And it was with theoretical nuclear engines. Inclination change is too expensive, it was just more economical to launch a maintenance mission. Or to scrap the craft and launch a new one.
« Reply #11 on: December 21, 2023, 11:09:43 pm »
I assume it would be a scheudled rocket with lots of maintenance bots (low cost) that go to different sats and work on them
like the bus, drops people off at different locations.
« Reply #12 on: December 22, 2023, 12:20:05 am »
Hello fellow kerbonaut!  :D
Yes, inclination changes are expensive fuel wise. It could work if the repair craft was servicing multiple sats in geostationary orbit all at around the same time. Then there'd be no inclination changes required, the repair craft's orbit wouldn't need to change much to move from one sat to another, and it wouldn't spend years waiting in space for the next repair mission. The sats would still have to be designed to have modules easily swapped and things could still go irreparably wrong (pun intended).
« Reply #13 on: December 22, 2023, 01:35:42 am »
hmm thats when you send the panel beaters into space on a special mission, when the chassis is dented
Offline Dan123456
« Reply #14 on: December 22, 2023, 05:05:58 am »
I personally like the idea of space maintenance robots  :)
The longer we can keep things up there alive, the less rockets we need to launch, meaning less space junk  :)
Sure some satellites will need to be replaced with new, better systems, but I would imagine a lot of others work perfectly fine with their current hardware  :)
LOL, first of all Soviet Union never tried landing a rocket booster, let alone reusing. Secondly SpaceX launching reused F9/FH for almost 100 times this year alone paints a different picture.
You might be correct about the USSR. I dunno. But the US was looking at / using reusable stuff decades ago. One similar to what u666sa is talking about was called the DC-X and it got abandoned only for Musk to take his inspiration from it years later. There was also the space shuttle which has put the most people into orbit to date.
Also, have they really reused boosters 10+ times? Or is are they just the space age version of the ship of Theseus?
I do not know the answer to that (and doubt anyone outside of the company does) but am just weary to take SpaceX’s word due to the copious amounts of bullshit Musk spews constantly. I.e. weren’t we meant to be living on Mars last year?
Again, I have nothing against SpaceX, just Musk.
« Reply #15 on: December 22, 2023, 05:08:38 am »
there is also probobly a global warming effect of launching rockets. its greener to repair with smaller payloads then to keep sending giant payloads and its smarter then trying to miniaturize things and limit potential
I wonder how many short term experiments and systems are stunted by power requirements. its like getting a 3 phase hookup in space to use a bigger sat for a rental.
The following users thanked this post: Dan123456
Offline fourfathom
« Reply #16 on: December 22, 2023, 05:17:24 am »
Well, we did send a five repair missions to the Hubble Space Telescope.  And it was cheaper than sending up a new Hubble.  And the ISS regularly gets repaired and updated.  These are high-priced and critical assets where it makes sense to repair rather than replace.
We'll search out every place a sick, twisted, solitary misfit might run to! -- I'll start with Radio Shack.
Online Simon
  • Global Moderator
    • Simon's Electronics
« Reply #17 on: December 22, 2023, 07:23:52 am »
Perhaps you could provide some evidence.
Offline wraper
  • Country: lv
« Reply #18 on: December 23, 2023, 02:36:57 am »
US may have looked into it but never tried actually building a reusable rocket booster. Calling Space Shuttle SRB reusable would be a big stretch, those were just empty shells splashing into the sea and which would be cheaper to discard rather than take apart, heavily refurbish and use for assembly of new SRB. DC-X was a tiny suborbital single stage rocket (huge difference between orbital and suborbital). Last time I checked the most reused F9 booster had flown 18 times and a few others 2-3 times less.
EDIT: Actually 3 other boosters have reached 17 launces already. Most reused booster today should fly for 19th time. Fastest reuse they achieved was 21 day.
« Last Edit: December 23, 2023, 02:56:31 am by wraper »
Offline Dan123456
« Reply #19 on: December 23, 2023, 05:09:29 am »
Na, the space shuttle boosters were reusable. Just the external tank was not.
“Once they were returned to Cape Canaveral, they were cleaned and disassembled. The rocket motor, igniter, and nozzle were then shipped to Thiokol to be refurbished and reused on subsequent flights.[13]: 124 ”
https://en.m.wikipedia.org/wiki/Space_Shuttle
I think you miss my point on SpaceX’s boosters. The question is are they really the same booster that first launched? Or do they just replace every single part after each launch and slap the same number on it and just call it the same booster?
I do not know the answer to that. I would like to believe that they can reuse them with minor repairs, but due to Musks track record of massive overstating capabilities / straight up lying, I can not trust anything that his companies say. Especially in regards to marketing.
Offline wraper
  • Country: lv
« Reply #20 on: December 23, 2023, 01:01:10 pm »
Do you understand that in SRB engine and propellant is the same thing? All that is left afterwards is an empty husk. They could not even reuse that without taking them apart into pieces, stripping all paint, etc, and from what I've read it the process spending 1.5 times more than it would take to just using brand new.
Offline Dan123456
« Reply #21 on: December 23, 2023, 02:01:00 pm »
Yes, I am aware how solid rocket boosters work. That is why they had to take them apart to refuel them.
Anyways, we are derailing this thread but you stated:
So I just wanted to point out that is not quite true.
Offline wraper
  • Country: lv
« Reply #22 on: December 23, 2023, 02:21:10 pm »
And I said it's a stretch to call them reusable. When you take maybe 20% of what takes to build the thing, take apart, heavily refurbish it and then use to build a new booster, it's very far from being reusable booster. Call it refurbishable booster shell, not reusable booster. Also it's way more complicated than refueling.
Offline BrokenYugo
« Reply #23 on: December 23, 2023, 02:42:13 pm »
As I recall from Feynman's autobio he gave a pretty detailed account of his visit to the shuttle SRB refurb facility.
Basically the empty tube would hit the water and, as one would expect, get all tweaked and twisted from the impact. Then once returned to land people would clean and straighten the sections out with hydraulics and hammers, and they'd by refilled and reassembled for flight. They were about as reusable in practice as a cardboard tube model rocket engine. A great case of just because you can doesn't mean you should.
« Last Edit: December 23, 2023, 02:45:13 pm by BrokenYugo »
Offline CatalinaWOW
« Reply #24 on: December 23, 2023, 06:27:11 pm »
There is quite a bit of reason to believe they are reusable.  For starters the externals aren't repainted and show the evidence of prior use.  But sure, that could be a smoke screen for complete replacement of the internals.  But doing a complete replacement of the internals in 21 days buggers my imagination and should give you a little pause.  Most important, NASA and the military customers who are buying many of the launches are watching very closely and they seem to agree.  And over time have changed their policy from requiring a new booster for their flights to accepting what are now called "flight proven" boosters.   I also find the fact that they are able to price launches at 50-75% of what other vendors can provide evidence.  Either they have found a way to manufacture these things far more cheaply than others, or they are re-using with relatively low refurbishment costs.  None of this may meet your standard for re-usable.  If you require that the only thing that happens upon a booster return is to stand it up, fuel it and light the fire, I doubt that it meets that standard.  But if you can re-launch $50 million dollar booster with a few million dollars of inspection and repair I think it counts.   It is also my guess that the inspection and repair costs have been dropping as they have learned and made adjustments based on the prior flights.  That database is rapidly growing, and will soon be larger than for any other space vehicle.
Caution with respect to Musk's statements is wisdom.  Assuming that everything his companies do is a lie is not.  Tesla cars aren't as good as Musk claims.  But they are generally serviceable vehicles with more on road mileage than all other vendors combined.  The Tesla powerwall is expensive but works.  Starlink works.
Find a way to hold Musk accountable for the falsehoods without throwing out the successes.
