Author Topic: Ordering from JLCPCB to Chinese address  (Read 820 times)
Offline AxkTopic starter
  • Country: by
« on: July 05, 2020, 12:04:02 am »
Edit: solved, see below.
Has anyone ordered from JLCPCB to a Chinese address?
They don't have regular post delivery to Belarus right now (DHL and Fedex are PITA here and quite expensive).
So I'm trying to order to a post forwarder address (Tiptrans) and it won't accept the address (in Chinese) that the post forwarder is giving even if I remove the Latin characters as it suggests.
The same address works fine with LCSC and I've one order delivered there already.
I guess this might be a bug that nobody cares about because the Chinese are using a different local version of JLCPCB.
« Last Edit: July 05, 2020, 12:27:16 am by Axk »
  • Country: by
Re: Ordering from JLCPCB to Chinese address
« Reply #1 on: July 05, 2020, 12:26:43 am »
In case anyone else runs into the same issue I had to  create a new address and it worked.
It didn't work with the existing address (synced from LCSC) where it originally had Latin characters, even after I changed it it somehow didn't pick it up and though that I still had Latin in there.
Creating a new address helped.
The following users thanked this post: thm_w, I wanted a rude username
