So... I'm not a religious person... I'm struggling to understand this. It's a random delay, so you move the switch, and the light comes on after a few seconds?
So, according to Jewish law, because your action did not directly induce some current to flow in a wire, that's OK? But can't it be said that you did induce a current, because the microcontroller/logic inside the switch will have changed states... even if that is a timer circuit, it's still got to start somehow. Uncertainty? What uncertainty? Does it use a quantum-decay RNG to decide whether you can use the light today?
Seems like two fingers firmly up to the lord Almighty to me.
And apparently you can't use filament bulbs because they are too similar to creating a "fire" (light via incandescence) yet CFLs/ energy savers are OK? Do they not know that CFLs use filaments to start? Are LEDs ok all the time?
