Has anyone built themselves a large-ish (i.e 6+ bays) NAS server recently?
If so what case did you use?
My current server is squeezed into an old Morex Venus 669 case. A couple of Icy Dock caddies allow 3x hot swap 3.5" and 2x hot swap 2.5" drives to be installed and there is a further 3.5" drive internally. Currently it has 20TB of disk in mirrored pairs (2x 6TB and 2x4TB), the two 2.5" slots contain 2x2TB drives used for "very near line" backup.
However it is starting to show its age and I'd like to upgrade.
Main duties are media serving (very popular with the family for the DVD collection), email & web server and, usually because it is powered up 24/7 my main PC.
There seem to be very few suitable cases on the market though - I'm looking at 8-bay NAS which can take a Z370 Mini-itx M/B, i7-8770 CPU (despite the shenanigans with Spectre I can't see Intel coming up with a sensible solution in a sensible time frame) and, given the CPU spec, ideally enough room to squeeze liquid cooling in. Not interested in o/clocking beyond perhaps getting as many cores as possible running at the full turbo speed. One of the 1st duties will be to transcode my current h.264 library to h.265 (purely to get a bit more life out of the storage space, though I would plan on almost doubling what is available with a pair of 8TB drives).
The U-NAS NSC 810/810A would appear to be good starting points but:
- they are rather expensive at £240 for the 810 without PSU
- I can only find one supplier with any stock in the UK, and then only a single 810
- no actual data, drawings or measurements on the 'net, no max fan height specified anywhere
- it looks a little, ahem, cramped internally.
- no room for liquid cooling
That leaves the Silverstone DS380 and, errm not much else. A couple of dodgy looking items on Alibaba.
To be honest the DS380 probably does fit the bill, it's a bit larger than I'd like but not too massive and it's a lot cheaper - however some reviewers have expressed concerns regarding airflow across the disks, one use even limiting himself to using every other slot to get temperatures down below about 65oC. It doesn't look as nicely made as the U-NAS case (not taht matters if i can't get hold of the latter).
Suggestions very welcome.
Edit: Ah, realised I didn't put size constraints in the "spec" which I had intended to do. Limited space means I'm looking for a case as close to the Morex as possible given the other requirements.
