Author Topic: Panasonic NCR 18650GA 3500mAh keeps dying after short period of use  (Read 1571 times)
Offline zillahTopic starter
Dear Experts
I bought 2 pairs of  these Panasonic NCR 18650GA 3500mAh High Current Lithium Batteries on Jan 2017 and Dec 2017 from a seller below :
https://www.lanplus.com.au/index.php?route=product/product&product_id=246
to be used on a headlight below :
https://www.ebay.com.au/itm/BORUIT-UPGRADED-RECHARGEABLE-CREE-13000LM-3T6-3X-XM-L2-LED-HEADLAMP-TORCH-USB/302095643393?epid=886556492&hash=item46564db301:g:gKAAAOSwwKxbtNGe:rk:1:pf:0
The one that I bought on Jan 2017 died on me after 10 months though I am not a heavy users and I am not charging them every day
The one that I bought Dec 2017 died on me yesterday
When I said died I meant not getting charged using different way of charging 1-Using USB car and 2- via a portable charger as in the snapshot below
https://imgur.com/a/VXZTRF6
Is this normal for the life span of the Panasonic NCR 18650GA 3500mAh ?
Thanks
Offline wraper
  • Country: lv
Re: Panasonic NCR 18650GA 3500mAh keeps dying after short period of use
« Reply #1 on: October 29, 2018, 11:12:44 am »
Nitecore charger should be OK. Dunno what your second charger is but it's very easy to kill lithium batteries with crappy charger. Likely internal pressure valve disconnected the battery from positive terminal due to internal pressure build up.
« Last Edit: October 29, 2018, 11:15:04 am by wraper »
« Reply #2 on: October 29, 2018, 11:15:11 am »
The other is via the headlight itself which has USB charging cables hooked to the flashlight to charge battries
« Last Edit: October 29, 2018, 11:42:45 am by zillah »
Online amyk
« Reply #3 on: October 29, 2018, 11:59:31 am »
Check what voltage they're being charged to... and what voltage they currently show.
Make sure that you really have a 4.2V charger, since some lion cells are now 4.25V or even 4.35V and chargers for those will quickly kill a 4.2V cell.
Offline NiHaoMike
    • Facebook Page
« Reply #4 on: October 29, 2018, 01:02:06 pm »
I had a battery fail in one of those portable routers way quicker than expected because the charger they put in charged it to 4.23V.
« Reply #5 on: October 29, 2018, 07:23:28 pm »
How can I check that and the current charger showing nothing ?
Thx
Offline wraper
  • Country: lv
« Reply #6 on: October 29, 2018, 07:34:59 pm »
Thx
As I wrote, most likely battery was disconnected from positive terminal due to safety pressure valve. So it's open, no current will flow.
https://batterybro.com/blogs/18650-wholesale-battery-reviews/18306003-battery-safety-101-anatomy-ptc-vs-pcb-vs-cid
