Author Topic: Parallel Printer Port to USB Printer Converter  (Read 3197 times)
Offline clonecrp
    • http://theclonestore.com
« on: October 14, 2011, 02:32:45 am »
Hi all:
I have a piece of test gear w/Parallel out and I want to print to a USB Printer instead of a parallel.
Thoughts anyone ... ?  :)
Thanks!
Doug
Offline IanB
Re: Parallel Printer Port to USB Printer Converter
« Reply #1 on: October 14, 2011, 02:40:17 am »
Hi all:
Thanks!
Doug
You're screwed?
Basically, you can't do this with an off the shelf solution. USB has taken over the world. Your only options are to buy a printer with a parallel port, or replace the test gear with a newer model that has USB output.
Offline joelby
« Reply #2 on: October 14, 2011, 03:49:57 am »
Does the test gear have a GPIB port? You might be able to use that to download data to your computer, though unless you need to do a lot of printing, it'll be cheaper and easier to rescue a throw-away parallel printer.
Offline Bored@Work
« Reply #3 on: October 14, 2011, 05:25:29 am »
Offline IanB
« Reply #4 on: October 14, 2011, 05:35:33 am »
Wow, some people have been very creative! That's a lot of work for a thing that is rarely needed.
Offline clonecrp
« Reply #5 on: October 17, 2011, 12:04:21 am »
HI Guys:
I can name several applications of converter. I originally considered a UART latch the data then stream to an CP2101 to convert TTL to USB.
To have a completed device is dinomite ! Looks like BoredAtWork has the Idea...  ;D
BTW the PLL out is for avery expensive hunk-o-gear ... to USB printer is supreme!
More thoughts anyone ?
