Author Topic: PC1602K-P9 LCD pinout  (Read 1277 times)
Offline jdev99Topic starter
« on: February 25, 2022, 02:34:04 pm »
Can any body help me with the pinout for this display please?
It is a "POWERTIP" PC1602K-P9 module (16x2 characters), based on a S6A0069 controller, which is similar to the HD44780.
It is from an old network switch
I traced out what I can, see attached schematic and photos.
Thank you for any assistance.
Offline amyk
Re: PC1602K-P9 LCD pinout
« Reply #1 on: February 26, 2022, 03:36:29 am »
If you have the device it came from, and a scope or logic analyser, you can find out the remaining pins. It's probably being used in 4-bit mode judging by the number of pins left over on your schematic.
Offline kjr18
« Reply #2 on: February 26, 2022, 09:26:59 am »
Hi, I found this datasheet, it might be what you're looking for: datasheet link here.
The following users thanked this post: tooki, jdev99
« Reply #3 on: February 26, 2022, 02:49:40 pm »
That is the one, thank you very much.  :-+ :)
How did you find it, if I may ask?
Offline kjr18
« Reply #4 on: February 27, 2022, 03:08:38 pm »
First I tried searching for "pc1602k-p9" then on images I found some photos from this page. Last post contains dead link to datasheet, but provides another parts number that shows what you look for.
The following users thanked this post: jdev99
« Reply #5 on: March 14, 2022, 01:13:57 pm »
Brilliant! I also initially tried to search for images, but only found this site: https://www.elektroda.pl/rtvforum/topic3408653.html
What search engine do you use?
« Reply #6 on: March 14, 2022, 01:31:48 pm »
Just for completeness, this display work 100% using the provided datasheet by kjr18:-+
It seems to be 100% compatible with the HD44780 and associated Arduino libraries.
Just take note, EN (pin9) and VO (pin15) must be connected to +5V.
« Last Edit: March 14, 2022, 01:34:24 pm by jdev99 »
Offline kjr18
« Reply #7 on: March 16, 2022, 02:51:56 pm »
I used Google. DuckDuckGo only shows this one thread on this one forum.
