Author Topic: Pencil eraser on protoboard test results  (Read 1383 times)
Offline kalelTopic starter
« on: November 24, 2017, 09:27:42 pm »
Some have mentioned using pencil erasers for cleaning various contacts as method that doesn't do much damage, so I wanted to test it on something, I took a cheap protoboard to do the test.
It seems to really clean things well, but in this case it will also fill the holes so it might not be a great method for this use.
I'm sure you can notice which area is cleaned (some partially which is good for comparison):
I assume the cleaned areas would take solder much better than the other.
Why the remaining parts of the rubber eraser are black, I'm not sure.
Offline TerraHertz
    • It's not really a Blog
Re: Pencil eraser on protoboard test results
« Reply #1 on: November 26, 2017, 02:13:53 am »
Fine metallic particles tend to look black. Same effect can be seen when polishing metal with Brasso and a cloth, or any polishing paste and cloth buffing wheels. The cloth becomes very black.
The following users thanked this post: kalel
Offline vk6zgo
« Reply #2 on: November 26, 2017, 02:28:27 am »
Keep a few toothpicks on hand to clean the rubber particles out.
If you have an air compressor, just blow them out.
