Author Topic: Bad Electronics Jokes  (Read 46225 times)
Offline eutectique
Re: Bad Electronics Jokes
« Reply #250 on: November 16, 2023, 10:43:59 pm »
‒ Do you have four-volt two-watt light bulbs?
‒ For what?
‒ No, two.
‒ To what?
‒ Yes.
‒ No.
The following users thanked this post: Ed.Kloonk, Berni, mairo, Gregg, MK14, Nominal Animal, MrMobodies, soldar, DavidAlfa, Roehrenonkel
Online MrMobodies
« Reply #251 on: November 29, 2023, 11:23:05 pm »
From a discussion in the Eevblog IRC about an overload relay for a contactor.
Q: Why wasn't one wired in to the HS2 project.
A: <coppice> HS2 = High Spending 2, the sequel
The following users thanked this post: MK14
Offline niconiconiTopic starter
  • Country: cn
« Reply #252 on: December 12, 2023, 07:29:13 pm »
Q: What do you say when Hammerstad & Jensen's microstrip formula underestimates signal losses due to surface roughness at high frequencies?
A: "It's only a rough approximation."
The following users thanked this post: MK14, MrMobodies
  • Country: cn
« Reply #253 on: December 14, 2023, 09:59:51 pm »
Q: Why does a Web-browsing PC eventually arc over and blow up in an electrical breakdown after a few years?
A: Too much tracking.
  • Country: cn
« Reply #254 on: December 15, 2023, 06:55:25 pm »
Q: What do you call a technical expert on circuit board gold plating?
A: ENIGneer
Q: Why does a circuit board factory make bare copper boards without tin plating?
A: It's too much of a HASL.
The following users thanked this post: Berni, MK14, Nominal Animal, MrMobodies, Roehrenonkel
Online MrMobodies
« Reply #255 on: December 28, 2023, 12:04:01 am »
A: What when they try to sell you Meanwell power supply knock off's?
A: They don't Mean well.
« Last Edit: December 28, 2023, 12:21:09 am by MrMobodies »
The following users thanked this post: mairo, MK14
Online MrMobodies
« Reply #256 on: February 06, 2024, 11:41:50 pm »
Q:What happened to a Chinese group at St Pancras station when Christina Lee Turned up?
A: She controlled them at a firmware level.
Proprietary to the CCP.
Joke in reference to a clash between a pianist, Brendan Kavanagh and the Chinese over a piano John Elton donated to St Prancras tube station in London.
It was pointed out in some followup videos that when Christine Lee turned up the group went from being very nice and friendly to very aggressive and nasty when Brendan refused to removed/edit them from his livestream saying it was public space in a free country and it isn't not China etc.
youtube.com/watch?v=65iwnI2hjAA
Removed https:// as I don't want video to auto play here.
  • Country: cn
« Reply #257 on: February 25, 2024, 10:44:37 am »
Q: What do you say when electronics engineers apply Laplace transform so they can do algebra instead of calculus?
A: It's a heavy side-step.
The following users thanked this post: Nominal Animal
  • Country: cn
« Reply #258 on: February 26, 2024, 09:58:51 am »
"If a power supply filter has a high quality factor, it means the filter is of low quality."
  • Country: cn
« Reply #259 on: March 15, 2024, 08:27:22 am »
Q: Why is it easier to measure a circuit in time domain?
A: It's not complex and there's only one step.
  • Country: cn
« Reply #260 on: April 01, 2024, 08:39:24 am »
Q: What's the difference between an authentic Li-ion battery and a counterfeit one?
A: For the former, the battery gets charged. For the latter, the seller gets charged.
Offline NiHaoMike
    • Facebook Page
« Reply #261 on: April 02, 2024, 03:12:19 am »
Had that problem a few times at work, needed a choke in series with the power supply to reduce the measurement noise, all they had were good quality toroids. My fix was to put a piece of scrap wire through the toroid and twist the ends together to make a shorted turn...
If only that's how it worked, most counterfeit sellers just operate from countries that don't enforce it well.
The following users thanked this post: niconiconi
Online MK14
« Reply #262 on: April 28, 2024, 02:12:36 am »
Q: Does anyone want a pile of dead batteries, I've accumulated?
A: If you do, you can have them, free of charge
Offline Nominal Animal
« Reply #263 on: April 28, 2024, 03:10:02 am »
No thanks, I've got enough trouble with my own piles.
The following users thanked this post: RoGeorge, MK14
