What are the best habits for charging your phone in this day and age? My last phone went through 3 batteries: the first one ended up swelling due to it being left on the charger a lot at 100%, the second was genuine battery but didn't last more than 12-18 months, by the 3rd battery I learned my lesson. I used a non genuine battery which had obviously less capacity, but I took it off the charger once it reached full charge. It has lasted til present day without swelling up.
Unlike the old phone, my new one, a Pixel 8, has a glued in battery in a sealed case like most new phones. So I would like to maximise its lifespan. So far I have only needed to slow charge the device up to 80%, which is plenty of capacity to get me through more than 24 hours. These seem like pretty basic conventional tips to maintain a battery.
However I read an article which proposes doing what I used to do:
https://akc3n.page/posts/battery-management/ie leaving the device fully charged and connected to power. In fact it proposes my current habits are detrimental to the battery.
While many of the points seem like they should be correct, ie a modern BMS should be able to manage charging and maintaining of a battery to maximise lifespan, my prior experience tells me otherwise. Also, I would tend to believe manufacturers prioritise battery capacity and charging speed at the expense of longevity. They have an incentive to perform well in immediate reviews and spec comparisons, but have little concern whether the battery goes bad after a couple of years and out of warranty.
The article also alludes to something I have wondered, whether the phone is able to operate purely on external power when it's connected, and avoid cycling on the battery to preserve it's life. Again that seems like it would make sense, if it doesn't result in the battery swelling due to a high state of charge.
