Probably at some level, direction, and intensity. The same RF that is used to deliver a signal to your laptop can probably completely melt the film so long as there's a bit of water around (like in the air).
The key difference with the sorts of EMR you're talking about (X-Rays, visible and just outside visible light like UV and IR) is that they are /considerably/ higher in frequency on a considerable order of magnitude, and as the frequency goes up, the damaging effects EMR can have usually intensify. Once you start getting to UV and onwards, EMR becomes ionizing.
There's a lot of, if, but, and or's here. What sort of RF? How intense? Directional/Focused?
