I looked at what went wrong in Chicago with the Tesla charging and it's not clear.
The company knows damn well what happened, they have the telemetry and should issue a press statement lest EV's get demonized for the wrong reasons.
I would expect a cold Tesla to refuse charging until the heater got the battery temps up, courtesy of the charger power, and then inititate charging at reduced rate.
But they would be really worried about battery Li-plating- which is terribly destructive to the batteries.
"Degradation of LiBs during operation is one of the most complicated and critical issues that involve the variety of electrochemical side reactions in all the LiB components. Lithium plating is one of the most important degradation mechanisms of the anode electrode. The main impact of lithium plating is severe capacity fade. It occurs under three main working conditions:
low-temperature charging, high C-rate charging, and high SOC charging."
source: Progress in Energy and Combustion Science
Lithium Plating Mechanism, Detection, and Mitigation in Lithium-Ion BatteriesMost of the unhappiness in Chicago, it appears due to the huge battery capacity temp derating, almost 1/10 capacity at low temps so the sudden range cut freaked people out. I haven't compared newer LiPO4 how they do.
People expected the usual 45 minute charge time, and while waiting for a charger station, things cool off. The battery is a stuctural component and imagine how much heater power/time it takes to heat a 1,000lb blob plus metal casing.
Diesel engines work fine here, there is a block and fuel heater but truck stops leave semi's idling constantly though. They never shut the engines off on big trucks.
