My view: Unless a responder has driven an EV as their primary (perhaps only) vehicle for, say, 9 years, their opinion is irrelevant and should be flagged as such. They know exactly diddly.
OK, I have a 2014 model year EV so I guess I can say something? Yes, EV charging stations are being built for various reasons but the observation that an EV charging station as a standalone business is hopeless if you expect a profit is still entirely true. That sad fact has nothing to do with the various reasons that EV charging stations are being built--those reasons being things like a very large fraud settlement with VW or businesses and municipalities putting them in because they are required, encouraged or seen as the socially responsible thing to do, or simply as a way of dominating the market like Tesla. But the EV charging business on its own doesn't work so there has to be another reason for someone to do it.
You might think that all that doesn't matter and the only thing you care about is that the stations are being built. Well, good luck with that in the long run and if you want an example of what might happen, take a look at L2 charging. Our 2014 EV does not have HVDC charging, only L2. That worked just fine for us for the first 5 years or so, charging mostly at home but using destination charging for certain extended trips. We still can do that sometimes, but not as reliably or often because the L2 chargers have been going away and the remaining ones are overwhelmed. There are no funds to maintain them and the business model is so bad that even paying fairly expensive rates won't allow the EV charging station owner to even maintain an existing, installed charger let alone install more, regardless of demand.
This hasn't killed off our EV use, just reduced our driving range a bit at times. We'll take a different vehicle for long trips as always and the only difference is what we drive on some intermediate runs. Home charging still works. But my viewpoint is that depending on public EV charging is not a good long term plan at this point as it will either collapse or become badly overburdened once the subsides and growth euphoria subsides. I already see lines at local EV charging stations, even the new Electrify America station near my house that really isn't on the road to anywhere.
