Not to mention alot of plastic is made with mystery recycled meat.
A proper plastics engineering handbook with specify glass beads or rods, I heard that you actually get all sorts of creative fillers like chalk, bits of crushed rock of various origins, other plastics that are a bit harder then the one you are using, ash/char... its sloppy joe all over again.
I suspect this is because testing plastic is difficult and expensive, and its one of those things where if you initially cut corners your problems won't show up for a long time. It's also a incredibly complicated material engineering wise (what else has so many different dynamics going on
Just imagine steel had some kind of liquid you had to soak in it).
I think you can get the idea about the nonidealities of plastic if you are able to detect 'new car smell'. I can't believe some people like that.
I find the most annoying aspects of materials engineering are coatings and plastics. They both never work like you think they will and you end up throwing a ton of shit out because the coating or plastic failed. And you need specialized engineers to do anything with them on a large scale cheaply (like going to injection molding is ass rape, or finding a trustworthy reliable metal coating shop.. and you need to train people how to inspect paint jobs). Ha ha, then you have coated plastics.
There are some high end engineering plastics that are a joy, like teflon, epoxy reinforced carbon fiber and the hard glass reinforced nylons that are made thick. These work decent so long you use the high end suppliers$$ and manage your supply chains well, don't use crappy old epoxy, and don't realistically think they will work right for any kind of gear system, plastic gear systems are a freaking joke for anything but the most infrequent operations. Sorry modern power drills, you should not be run for any decently long periods of time
Heat freaking destroys the properties of plastic, even nice expensive ones.
Have you ever found your chrome plated plastic toilet paper roll holder to actually have a useful life time? Or zinc plated cheap shower stuff?
I think the majorly bad part of plastic hate comes from the fact, that when you present a man with the option to make a mold, and encourage that he optimizes the shit out of every complicated stress point like variable angle curves (infact hold a gun to his head to encourage this), you will get shit that is weak. Even with complicated CNC machining, if you make something out of a billet you don't actually save that much making the surfaces super thin because you need to remelt the scrap anyway and you get low prices for that compared to a inspected billet. Plastics are usually fed in an auger so you get the feeling that you are saving money by using less right off the bat. Molded metal/die cast is like this too, but for some reason it just ends up working better, maybe because the stresses are more normal and there are no liquids. I found usually the only reason a manufacturer wants to migrate to plastic shells over metal ones is because he has a promise of volume discount and alot of slick sales people telling him how great plastics are despite all their deficiencies.
You might not actually save money if you wanna do plastics right. Would you go to 22 gauge aluminum for your chassis? That's what plastics people end up doing. They need to be thick. Then you can benefit from the dielectric effect and complicated geometry, but not necessarily cost.
I end up finding things inside of chassis like plastic brackets that have similar dimensions to the steel ones used before. Maybe it works out on paper, and maybe they have thick steel ones because it was available, then it turns out that aspect was not engineered right and it turned out that the super-too-strong-steel-chosen-by-market-forces-that-we-are-wasting-money-on was actually a design requirement that happened to solve a design flaw.
And plastic/dielectrics make people totally ignore EMI and shielding. They think they can get away with paint!
Like screw driver handles, that's a great use of plastic. I actually don't want metal on a screw driver handle, unless its a complicated ratcheting screw driver... but if they want to use a 1 inch thick plastic rod to make a screw driver handle that does not get super cold in the winter and generally prevents me from getting zapped, I will take that with a smile.
And since we are looking at health effects, look at all the microbeads/plastic microfragments found in water and everywhere else. Bottled water is not safe if you are worried about them.
Nothing gives me quite that 'mother fucker please' feeling as a plastics failure. You know you will be there with a soldering iron jamming metal reinforcements and buying expensive glues with low shelf life to make a decent repair (like the high end black plastic welding epoxy from a autozone lasts about 1 year and you will use it only once). It's also one of the most vile smelling consumer compounds I have come across. Jesus fucking chirst can you make it smell any worse without using sewer gases and federally listed poisons?
https://science.slashdot.org/story/18/08/20/2232252/tiny-plastic-is-everywhere (about microbead contamination)
I think we would mostly be happier with high end ceramics though
but their fragments might pose the same issues. But seriously who would take a fucking PDIP over a CERDIP if given the choice??
I doubt you can beat plastics in terms of human body interface though, for grips, medical equipment, etc.. it just has the organic properties you need to mate with the skin.. so its a good thing for our longevity that we research plastics heavily I think. I do like rubberized grips on tools.
