But I'd say consider getting two npn+pnp chips, they're more readily available, cheaper, and potentially take up less board space and they're super cheap :
http://uk.farnell.com/nxp/pumd13/transistor-digital-dual-sot-363/dp/8738327RL
This is no good at all if you need a matched NPN pair and a matched PNP pair for current mirrors, differential amps, multipliers, log-antilog circuits, etc. If you don't need matched pairs, you can just use cheap single transistors anyway.
It traditionally was hard to get good NPN transistors and good PNP transistors on the same die so that is why arrays like the CA3046 with only NPN transistors were common. The PNP transistors often used to end up as slower lateral transistors with poor gain and bandwidth.
I have never heard of the THAT340P14-U mentioned above, but it looks like the THAT corp has done a good job with 300MHz+ NPN and PNP transistors, and a typical offset of 0.5mV for both.
