Thanks seanB. Interesting! When I did a quick google about the LHC, I noted the huge energy requirements and one proviso that Wikipaedia mentioned was the power contract is on an "Instant cut off" if loads need it basis, your comments on back up for a 'simple' medical imaging MRI machine made me think as I work next door to one and the cooling fans work day and night, the 'back up' power supply and the switch off routine for the LHC must be complex.
I will tackle my Radiologist friend a little more about the switch off routine, I suspect the MRI Radiographers have more to do with that side of things, as an aside he had some photos of the room they are about to install a new MRI machine in, the copper plate lining was impressive and the single door also part of the Faraday cage. The venue is directly over a car park and once a car is parked directly below the MRI unit, for consistent field density in the machine, the car can't be moved without a 20min or so recalibration, staff carpark!!
