Author Topic: Police Helicopter Infrared  (Read 1665 times)
Offline apellyTopic starter
  • Probe
« on: March 20, 2018, 10:48:29 am »
Discl: I did zero research...
So, there's a helicopter circling/ellipsing/hanging about at the moment.
I thought I'd take a look through my cell phone camera. I wondered if I'd see a cone of light as they track whoever they're after.
But no. I see nothing.
Are they using passive IR, or is something else happening that I haven't thought of?
Online jpanhalt
Re: Police Helicopter Infrared
« Reply #1 on: March 20, 2018, 10:54:32 am »
I suspect passive IR, which is at a wavelength much longer than your cell phone can detect.
  • Probe
« Reply #2 on: March 20, 2018, 11:11:08 am »
If you see helicopters, put on your invisibility cloak; or your mylar thermal blanket...
Offline Mr. Scram
  • Display aficionado
« Reply #3 on: March 20, 2018, 11:26:12 am »
I think there's a lot of footage of people who hide and where heat starts leaking out after a while. You can't stay hidden forever, you inevitably heat up your surroundings.
Offline Brumby
« Reply #4 on: March 20, 2018, 11:28:10 am »
It's passive.  Has to be.
Illuminating a scene simply makes everything brighter.  A suspect can simply avoid detection by not moving as they will be just as illuminated as the surroundings.
By having a camera sensitive to the longer wavelengths, body heat shines like light bulb when the rest of the scene is cooler.
PolAir in NSW has FLIR.
Online Zero999
  • 0999
« Reply #5 on: March 20, 2018, 11:33:42 am »
Yes, 9–14 µm is typical. You'll be lucky if your phone camera can see  down to 1µm.
  • Probe
« Reply #6 on: March 20, 2018, 12:05:11 pm »
No need to hide. You're literally invisible. It's a walk in the park.
Offline Brumby
« Reply #7 on: March 20, 2018, 12:10:06 pm »
So - you reckon you can "green screen" the Police's FLIR?
Impressive.   :-DD
The following users thanked this post: apelly
  • Probe
« Reply #8 on: March 20, 2018, 12:30:50 pm »
What'll really screw them is the yetti shaped hot water bottle footprints
Offline Brumby
« Reply #9 on: March 20, 2018, 12:36:50 pm »
You have this >:D streak...
