Hi all,
First time posting, but I have browsed the forums every now and then in the past. I warn in advance this is a longish read:
Basically I have just taken a job as an electronics engineer for a small company (say about 10 employees) making some simple devices for automotive applications, nothing exceedingly complex. I was hired as the business previously had all their electronics design done externally, now they have decided to expand somewhat and they want an elec engineer to 'quickly' be able to develop new designs, products etc. (and to save money presumably). When I applied I did not know but essentially I will be 100% responible for all engineering, the first engineer they have ever hired. Now, this sounds ok probably for most, but I don't have a huge amount of experience. I graduated a few years ago and have done a little work since (mostly doing postgrad study), and electronics has always been my thing since I was 5: I am not concerned about actually being competent to do the work, however, to be effectively 100% directly responsible is quite a leap. (Also, for various reasons (which are irrelevant here...), I absolutely had to take the job, so I want things to go 'well'
Now this company has no in house workshop, engineers, anything in terms of electronics engineering etc, so I need to get everything going from scratch so I can do the work.
Obviously, part of my job is board design, which I also do not have so much experience with. I have done some small projects, although a couple of years ago. I have used some free tools, I played around with kicad a while ago, I have used Altium in the past (years ago though, and my memories of it are of a program which continuously hangs and crashes, not so nice, but maybe it's improved?). Essentially what ever route I take I will need to (re)learn pretty quick. (these are not too complex designs, microcontroller, misc components and logic, a few different connectors standard and unusual automotive ones). So seeing as it's not my wallet that will be raided (but also considering all of the above ad below paragraphs...) what do you reccomend?
The other thing is equipment for a functional electronics 'desk-workshop-bench-office-thing etc' - since they have nothing I need to specify everything and probably source it. Of course I had (had to get rid of everything as I moved...) my private workshop at one point, all tools equipment instruments etc, but I was never at the point where I had to 'buy everything at once', these things essentially accumulated as I needed and collected them. So considering, again, everything above, what do people reccomend in general? Oscilloscopes, function generator, power supply, soldering gear, multimeters, tools? (you don't know what you need till you go to use it and you don't have it, if you have any things you think are essential I don't list, say it!) I have to get this stuff set up with a reasonable cost and obiously functional enough for my work. I have owned a few rigol things in the past and would probably go for their scope and function generator, any general advice about models etc? I used to have about 10 different multimeters, heaps of tools, all kinds of gear and other things, all accumulated over time, now I have to get 'everything' new from scratch, I am really a little lost where to start (and spending someone elses money you need to at least have a little justification/excuses...).
Sorry these are 'long' questions, if it were my own business or hobby I would just go as I like, if I did somehting not so effective I could just try something else to get things going well, but now being responsible for someone else's business means I need to do things 'right'...
Any thoughts? advice?
