hello everyone this might be a silly question, but it is what is stopping me from buying my glass for my solar panels so i would like a answer so i can get to work.
i first just wanted to say that i know this forum is really not the home for this question but maybe someone out here could help me out.
Just to let to know where this question came from im making my own solar panels.
I went out to look for glass for my solar penal and i came across that polycarbonate blocks out UV rays from the sun which idk if that means less sun light that will hit the solar cells.
if this is so then i will not buy polycarbonate but if not then i really think i should.
i will go with acrylic as a back up unless someone else has a better idea.
And last quesion if you made your own solar panels what glass did you use, and where did you get it from.
Thanks,
Joe
