Author Topic: Poor explanation... or is it me?  (Read 1459 times)
Offline etiTopic starter
  • MOD: a.k.a Unlokia, glossywhite, iamwhoiam etc
« on: December 11, 2022, 06:23:56 am »
Is it me, or is the theory of operation of this camera flash circuit, worded poorly?
http://www.increa.com/reverse/dc/index.htm
« Last Edit: December 11, 2022, 06:27:26 am by eti »
Offline IanB
Re: Poor explanation... or is it me?
« Reply #1 on: December 11, 2022, 06:50:26 am »
I think the explanation is laid out logically. Following it is easier if you have a print out and mark various parts with a pencil as you go along.
It does slightly skip over the reset part of the charging oscillator, but if you have followed the previous steps you can fill in the gaps.
« Reply #2 on: December 11, 2022, 07:17:36 am »
Thanks. So much.
Offline Brumby
« Reply #3 on: December 11, 2022, 11:51:09 pm »
That reminds me ... I still have a couple of hundred boards I recovered from such cameras some time ago.  I remember approaching film processing establishments (now long gone) and asking them to hang on to the carcasses for me.  Some refused (because others had requested things be saved, then never came back to collect them) but some were agreeable.  I made sure I returned regularly to collect the booty - with an enthusiastic Thank You - and to let them know when I was done.
The recovered AA batteries still had an appreciable amount of energy in them.  Even after giving some away, I didn't have to buy any for a couple of years.
The following users thanked this post: tooki, MK14
Offline IanB
« Reply #4 on: December 12, 2022, 12:04:46 am »
Each one charges the flash capacitor to about 300 V.
So if you were to put 100 of them in series you could get about 30 kV with close to 1 kJ of energy behind it  >:D
That would be enough to make the most enormous bang--not to mention being incredibly dangerous  :o
Offline David Hess
  • DavidH
« Reply #5 on: December 12, 2022, 07:32:03 am »
I am not surprised.  Blocking oscillators are weird.
I know first hand that high voltage DC sources should use as little capacitance as possible for safety.
« Reply #6 on: December 12, 2022, 08:16:25 am »
I once connected a few boxes full of PP3 9V batteries together in series, clip to clip, and then grabbed a wire and made a nice searing arc. I'm pretty sure I was aware of the danger, but oh boy was it fun! I think it was about 100 of them.
Offline dmills
« Reply #7 on: December 12, 2022, 12:27:04 pm »
High school design and technology, (Now I think called 'resistant materials?), I was allowed to build a guitar amp but it had to be battery powered.
Mine was, a pair of EL34s, lead acid cyclons for the heaters and 60 PP3 in series for the plate. They were nicads and I learned a lot about fusing HVDC on that project.
We will gloss over the charging harness (1200V bridge off the mains with a series resistor) for the B battery.
The following users thanked this post: pardo-bsso
Offline Brumby
« Reply #8 on: December 13, 2022, 11:52:05 am »
Your >:D is quite the understatement.  It needs to be an order of magnitude or two larger.
Offline Brumby
« Reply #9 on: December 13, 2022, 12:22:59 pm »
.... though I do have a 30kV voltmeter.   ::)
Offline David Hess
  • DavidH
« Reply #10 on: December 14, 2022, 12:08:05 am »
I think the biggest capacitor bank I have worked with was the plate glass capacitor on my big tesla coil.  It was about 0.1 microfarads and 20 kilovolts so only 4 joules, but it sure was loud when it shorted out.
Offline IanB
« Reply #11 on: December 14, 2022, 12:46:05 am »
Using E = ½CV² I think that would be 20 J, so no wonder the bang?
