Author Topic: careful trusting your supply chains too much, fraud @ NASA  (Read 2824 times)
Offline coppercone2Topic starter
https://science.slashdot.org/story/19/05/01/1352235/nasa-says-metals-fraud-caused-700-million-satellite-failure
That's some sad shit, ripping off NASA.  :'(
as the first slashdot response says, stunningly reminiscent of 'the china syndrome'.
« Last Edit: May 02, 2019, 01:44:58 am by coppercone2 »
Offline OwO
  • Country: cn
  • RF Engineer.
Re: careful trusting your supply chains too much, fraud @ NASA
« Reply #1 on: May 02, 2019, 02:12:09 am »
No surprises here. It's a US supplier too, nothing to do with China.
If something is mission critical it's mandatory that you do your own testing and not rely on certifications. After all, your supplier is not an insurance company and should a part fail they can not be liable for all collateral damage. In general no supplier will sign a contract that holds them liable for collateral damage because it is possibly unbounded.
Email: OwOwOwOwO123@outlook.com
Offline DimitriP
« Reply #2 on: May 02, 2019, 02:59:23 am »
Easy there .....
Here is what the reference to China means:
"China syndrome" is a fanciful term—not intended to be taken literally—that describes a fictional result of a nuclear meltdown, where reactor components melt through their containment structures and into the underlying earth, "all the way to China."
re:  https://en.wikipedia.org/wiki/The_China_Syndrome
Offline windsmurf
« Reply #3 on: May 02, 2019, 03:04:30 am »
Ripping off the government, or religious organizations, or ?  Does it make any difference?
And I always wondered... what does China have to do with the China Syndrome?
Offline schmitt trigger
  • Country: mx
« Reply #4 on: May 02, 2019, 03:09:07 am »
It is a figure of speech, made famous by the 1979 film of the same name.
Offline helius
« Reply #5 on: May 02, 2019, 03:12:45 am »
What does Manchuria have to do with the Manchurian Candidate? They are just references to works of literature.
Offline hamster_nz
« Reply #6 on: May 02, 2019, 03:13:04 am »
If the uranium melts and forms a large, critical mass on the floor of the reactor hall it will "melt a hole all the way to china".
In practice it hits the water table and then things go bad...
« Reply #7 on: May 02, 2019, 04:34:11 am »
its a classic movie.
in the movie there is a fabrication company that makes some kind of subassembly used in the nuclear reactor and they falsify x-ray welds inspection, this leads to increased vibration of a pump that causes some kind of systemic failure (I think it trashes a level switch and confuses technicians too) ( i want to say the cracks in the welds decrease their stiffness or something)
It's called the china syndrome because of the reference to melting through to the other side of the earth, and I want to say the reactor in that movie was of unusually large size.
« Last Edit: May 02, 2019, 05:31:56 am by coppercone2 »
« Reply #8 on: May 02, 2019, 04:37:44 am »
its nasa of all things. it ruined a scientific satellite
Offline DimitriP
« Reply #9 on: May 02, 2019, 05:26:11 am »
Reedin is overrated   :palm:
Online David Hess
  • DavidH
« Reply #10 on: May 02, 2019, 02:24:36 pm »
Things are bad enough before it gets that far and if it does, and water is hardly the worst thing it could hit.  In practice large parts of what it melts gets incorporated forming corium until the surface area is large enough and the reactivity is low enough for it to solidify.
Offline andersm
« Reply #11 on: May 02, 2019, 03:22:04 pm »
So this phenomenon is no longer exclusive to Japan?
Offline thm_w
  • Non-expert
« Reply #12 on: May 02, 2019, 08:09:38 pm »
In house QC is so important. Even if they had not tested it internally, in hindsight they could have looked at the x-rays and noticed they were all the same. No one thinks these kind of lapses in quality will happen though.
After investigating, nuclear reactor supervisor Jack Godell (played by Jack Lemmon) found a problem with one of the pumps which caused it to vibrate. Looking for the cause, he discovered that, instead of x-raying all of the welds, the contractor had used the same x-ray and just changed the reference numbers. This meant that there were welds that had never been properly checked during construction. A bad weld was causing excess vibration and the reactor to scram (stop and restart) and could have lead to a catastrophic failure of the cooling system, causing a complete meltdown.
« Reply #13 on: May 02, 2019, 10:44:40 pm »
you should watch the movie, its kind of explained that management is shady. Riveting movie.
Offline rstofer
« Reply #14 on: May 02, 2019, 10:52:33 pm »
Usually, the welds are tagged with lead letters and digits that show up on the xray film.  There is no mistaking substituted films but it is possible for the QA department to not notice that the same film shows up over and over.
https://www.alibaba.com/showroom/x--ray-lead-letters.html
There is usually a source inspector witnessing the welds and the xray process.  "China Syndrome" was a good  movie but I wouldn't try to derive 'facts' from it.
Offline extide
    • Rovitracker - Rental management AND Real-Time data!
« Reply #15 on: May 02, 2019, 10:56:54 pm »
Two, actually.
It appears the company in question got off pretty easily IMHO, they cost NASA $700M in the failures but were only fined $46M and I think one low level guy went to jail. Top brass needs to be put in prison for quite some time and fines need to be much higher!
Online David Hess
  • DavidH
« Reply #16 on: May 03, 2019, 03:54:24 am »
Offline hamster_nz
« Reply #17 on: May 03, 2019, 05:14:10 am »
Offline Richard Crowley
  • KJ7YLK
« Reply #18 on: May 03, 2019, 05:35:48 am »
This has been going on for decades. Why is this news?
Because a satellite was affected this time?
Even us hobbyists concern ourselves with getting genuine parts.
And the chances of counterfeit parts coming from anywhere but China seems vanishingly low.
It doesn't seem logical to lay all the blame on the vendors.
They get counterfeits slipped into their supply chain beyond their control or detection.
Have we forgotten the FTDI debacle already?
https://en.wikipedia.org/wiki/FTDI#Driver_controversy
Offline harnon
  • Is this thing on?
    • My Personal Website
« Reply #19 on: May 03, 2019, 11:21:46 am »
Or as we've had recently in Melbourne, fireproof cladding on highrise towers which... isn't.
Offline windsmurf
« Reply #20 on: May 04, 2019, 12:36:35 am »
If there's any policy in China I like, its this.  We should adopt it.
https://www.businessinsider.com/chinese-white-collar-criminals-death-sentence-2013-7
« Last Edit: May 04, 2019, 12:57:58 am by windsmurf »
Offline soldar
« Reply #21 on: May 04, 2019, 08:00:22 am »
When I was a teenager, avid to see naked ladies, I was told "when you've seen one you've seen them all". I soon found out it was not true at all.
A gynecologist in Chile has been giving the same ultrasound print to his patients since 2011. One of them saw the ultrasound of a pregnant friend in Facebook and was surprised to see the same ultrasound. The doctor is now being sued. https://www.20minutos.es/gonzoo/noticia/medico-engana-embarazadas-misma-ecografia-3622501/0/
So, it seems some people subscribe to the notion that "when you've seen one you've seen them all".
