Dave & deadlylover: your fuse boxes look positively futuristic. I mean, you even have
a box.
1920/1930's Californian bungalow in Sydney, no solar and only single phase:
I think the upper board is screwed to the wall, not hinged. Maybe the service fuse is behind that? At least it looks like there is no asbestos (if you ignore the roof above).
Lower Hager box with DIN-rail inside was added by sparkies to modernise the place some 20 or more years ago when I was very young.
Wasp at the top right is to keep guard, make sure no one steals our electricity.
Aww it's got babies
Meter is "properly of St George County Council". Sadly that later became Ausgrid ("bring back the PMG!"). I love these mechanical types, it'll be a super sad day when it gets replaced by a Borg-personality smart meter that has no spinny bits.
From left to right:
- Main switch
- K = 40 amp supply for electric pottery kiln out back
- 32A kitchen oven. Not protected by the RCD, something I noted when last repairing the oven.
- RCD (in theory covers everything to the right of it)
- A single 20A breaker that supplies all of the pottery studio building out back (LOL I expected much more, but I don't think it has a sub panel ???)
- Various house internal breakers
The hager surface mount box's lid holds on through the hopes and wishes of one screw at the top right that doesn't do anything. Inside:
(Don't blame me for any of this, I've never touched this panel beyond flipping breakers. Not my house, not a sparky)
It looks like they chose to use both of the brass blocks at the top for neutrals (the one on the right is probably post-RCD), ...but then twist the earths together and just tape them? Huh? Lol. Maybe that's fine, I don't know, but I would have preferred at least some sort of connector to keep force on the copper strand mating surfaces (I believe this avoids corrosion creeping in as easily?).
If you squint you can see bars spanning the bottoms of the breakers. I presume these are the actives. I'm sure the rust is there to make it marginally safer against accidental contact
EDIT: Sadly no it's copper
That's it, unless you want to see some haphazard connector boxes strewn in the attic above the plaster ceiling. EDIT: Heater is gas, stove is gas, bigger kilns are LPG bottle.
