Author Topic: Power supplies being damaged by ugly loads--solutions?  (Read 2083 times)
Offline IanBTopic starter
« on: June 03, 2012, 10:49:43 pm »
This chap here on another forum has a problem of power supplies failing in use:
http://www.candlepowerforums.com/vb/showthread.php?339158-Variable-Regulated-DC-power-supply-type-and-protection-advice-sought
He is evidently using the supplies to power and test ballasts for HID lamps and similar things. Either due to poor experimental technique or exceeding the limits of the supply he is breaking his supplies.
What would be solutions here? Better test protocols? Different or better quality supply? External power supply protection?
Offline ModemHead
  • No user-serviceable parts inside.
    • Mr. ModemHead
Offline Satchmoeddie
Re: Power supplies being damaged by ugly loads--solutions?
« Reply #2 on: June 03, 2012, 11:53:31 pm »
Why not a 240 VAC Variac @ 10 amps and add a fast blow fuse to the thing if it doesn't have one already. DC power supplies for HID lighting?? I used a vairac with an ammeter and a hi pot testing those things for someone, not a DC supply. Yes, I wanted to shoot myself!  I was so bored!
