Author Topic: Power supply 12volt need to increase 14volt  (Read 394 times)
Offline Ali Rao
  • Country: pk
« on: August 07, 2018, 08:09:58 am »
Hi All.
need to increase server power supply 12volt to 14 volt for battery charger. how to modify please advise.
Online Kjelt
Re: Power supply 12volt need to increase 14volt
« Reply #1 on: August 07, 2018, 08:32:44 am »
Add a 2V battery in series.  :)
No serious, you write no typenr no specifications no pictures nothing, do you know how many server supplies there are in the world ?
Your chances are slim though, best bet is to find a potentiometer where you can fine adjust the output voltage, to find it we need pictures of the pcb.
Offline NiHaoMike
    • Facebook Page
« Reply #2 on: August 07, 2018, 02:21:27 pm »
If it's a surplus HP server PSU, disabling the OVP takes quite a bit of rework. I think there are actually two OVP mechanisms that I had to disable in the 1200W that I hacked into a charger for a 4S LiMn pack. And then a bit more hacking to turn it into a current source instead of a voltage source like it was originally.
