Author Topic: Powerfull UV-C led  (Read 1614 times)
Offline GreggDTopic starter
Powerfull UV-C led
« on: April 25, 2017, 01:39:42 pm »
From; Jessie Lin, DIGITIMES Research, Taipei [Monday 24 April 2017
digitimes.com/news
"Japan-based Nikkiso has developed 280nm UV-C LED devices with optical output power of 75mW for use in disinfection. Nikkiso has cooperated with its US-based subsidiary AquiSense Technologies to offer water purifiers, with the smallest model equipped with three UV-C LED chips able to purify 2-3 liters of water per minute."
That is a lot of power from an LED at 280nm.
Offline Paul Moir
Re: Powerfull UV-C led
« Reply #1 on: April 25, 2017, 07:15:14 pm »
I wonder what the efficiency will be like?  The last time I checked, they were very poor like an old 70's era LED.  They could be really useful in off-grid water treatment where the instant-on capability can overcome less than stellar efficiency.
Offline thm_w
  • Non-expert
« Reply #2 on: April 25, 2017, 08:44:34 pm »
75mW seems like a miniscule amount of power.
You can get quartz T5/T8 tubes that are 30-40% efficient, so 20W tube is 8W of germicidal output. With that you can process perhaps a few GPM.
Although of course you can't get small tubes like these LEDs.
I'm surprised if it can do 2-3 LPM, thats impressive if its a realistic number.
Offline Paul Moir
« Reply #3 on: April 25, 2017, 09:08:15 pm »
I've often wondered if it would make more sense to do up a fluorescent bulb with inductive excitation for frequent start/stop type purifiers.
Last time I looked LG Innotek ones did something like 2mW with 140mW in.    And they aren't exactly cheap!
« Last Edit: April 25, 2017, 09:10:24 pm by Paul Moir »
