Hey!
I'll post a diagram in a minute, but this is one of those 'musings' that hit every once in a while...(I heard Edison did that).
Thinking goes, a conventional OP-AMP circuit often has gain controlled by a little resistor network, such as having a 1 to 2 ratio in the two resistors, for having GAIN controlled actively. That example feeds back at 1/2 which causes the circuit to 'control' stabilize at GAIN of 2X. All conventional. But I've started thinking, that feedback signal is in the PAST, from a time-line point of view, even if it's a short delay.
What is possible, if your feedback term is up to date, meaning no (effective) delay ?
Of course, any circuitry will have a propagation delay, even the wires having a smaller delay contribution.
Imagine your 'Predictive' block has a digital processor, and you are passing a (predictable) sine wave, and thus that processor could adjust the output phase. I'm talking about a rather capable little component, often much more complex than the analog OP-AMP and passive components, in bulk.
Containing moderate, or even larger RAM resources, and perhaps with an AI slant to it !
The sine wave example was just for illustrating the set-up, and I don't know a huge amount regarding predicting noisy signals, but some 'Enterprise' related aspects would be such things as:
Example: Delivery truck comes every Tuesday, approx. 9 am, causing some circuitry activity. The AI feedback component knows this, and can predict certain functions and sequences very likely. An activated motor would perhaps run to a STOP switch soon, which this 'feedback element' predicts. Of course the enterprise activity is on a way higher scale, than immediate OP-AMP component signals.
That's a casual musing.
