I am interested in building a house on land I already own, however I am not sure if I should opt for the traditional cement block house or get a company that is specialized building prefabricated houses instead.
It is my understanding that prefab houses are much faster to build and cost slightly less per SQM to build but you are somehow limited in terms of design as they use precast steel reinforced concrete instead of cement blocks and use "modules of 6 by 4 meters that can be opened to build a room size of 8 x 6 meters.
My land is at 1000 m of altitude and covers around 1200 SQM of space. It snows for a few weeks during the winter when the temperature can go slightly below freezing just FYI.
This is the company I am considering dealing with:
https://megaprefab.com/If anyone would like to share the pros and cons of each to help me decide on which route to go, I would highly appreciate it!
