Author Topic: Prius smart key repair I did  (Read 565 times)
Offline Nickk2057Topic starter
« on: May 30, 2020, 12:52:45 am »
So I was trying to figure out why my smart key would not be programmed to my car. It uses the 134.(something)kHz oscillation within the car. But would not get picked up by the car. So by checking the other working remote I found this problem. a TINY surface mount resistor link went open circuit. So I went and put another resistor from a donor board and fixed it and got it programmed to my 2005 Toyota Prius.
just keep believing in yourself.. you can do some remarkable things in your life when you break through the ice and make things happen with the stuff you make
The following users thanked this post: I wanted a rude username
