Folks still seem to think the only problem with all haveing a Tesla or equivalent cards is with batteries or "some solar panels". So, here's some ballpark figures. Every single one probably has a 2x error factor, but hey, they're free
I go through about 2 tanks of diesel per month. That's about 1200 litres per year. Diesel is about 40 000 000 J/kg. Density? Say, 0.9kg/l. So total yearly is about 12MWh. Let's put an IC engine's efficiency at about 50% (generous, I know
) So you're looking at 6MWh/year for a single car. Assuming no grid losses, conversion losses or any other losses (again: generous) and assuming an electric motor is 100 efficient (yes, generous...).
A large nuclear reactor puts out 1GW at full toss. Assuming no downtime, maintenance, the grid that can handle 100% at all times, no peak loads, perfectly balanced etc etc and you end up with about 1 nuclear reactor for some 800 000 cars. That is of course, fairly optimistic given all the above optimistic assumptions, so it's probably more like half of that.
Doesn't sound too bad? Of course, personal transportion is only a relatively small portion of it all. Trucking, trains, busses,... All could be EV, so you need to add a lot more power to your shopping list.
Still sounds good? The odd thing for me is that EV vehicles don't make any sense. Or actually, they do. But
if there was an abundance of relatively cheap, clean electricity there would be
so much things that could be transitioned
before you would try to fit a elementary non-mobile technology on a mobile thing such as a car. Per example, those heating their houses on fosil fuels burn
more fuel annualy than their cars do. And to heat something like a house on electricity is a walk in the park, technically, compared to get a car of fosil fuels. Same goes for a million industrial processes.
Solar? Just put some panels on the roof? Let's take the 6MWh again. Around these parts I believe that you can expect about 1kWh per installed Wp. So, about 6kW is required. Or, say, some 60m² well oriented roof. Or 120m² if you have two cars. More roof than most folks have.
