Author Topic: Proprietary batteries  (Read 1901 times)
Offline StonentTopic starter
« on: November 25, 2013, 05:11:38 am »
My Jeep has a rechargable flashlight that snaps into the ceiling. I've only had a need for it about 3 or 4 times but it stopped working about a year ago. Today I finally popped it out and opened it up and it has this.
http://www.siambattery.co.th/images/Varta%20V500HT.jpg
The specs say 500MaH 1.2V NiMhwhich is basically a rechargable AAA battery.
The Varta battery sells for about $15 on ebay. What was the point of using this battery? A AAA battery would have been perfectly fine. Grrr.
Offline nukie
Re: Proprietary batteries
« Reply #1 on: November 25, 2013, 05:41:08 am »
Varta advertise this button cell designed for trickle charging, overcharging capabilities and special seals for extreme outdoor operations. I don't think it look like an AAA battery. Many electronic auto mains timer uses this for clock battery, and it gets pretty hot when plugged in, its pretty good battery as far as I know.
« Last Edit: November 25, 2013, 05:47:18 am by nukie »
« Reply #2 on: November 25, 2013, 05:46:11 am »
Well since it was covered in crusty green crystals... I'd probably have preferred the AAA battery. I might try to hack one in there if I can.
Offline Bored@Work
« Reply #3 on: November 25, 2013, 05:58:30 am »
2 Euro at this shop in the Belgium. Price is almost too good if it is normally $15 http://www.microbatteryshop.com/PBSCProduct.asp?ItmID=11707521
