Author Topic: Quality of old Chinese Valves/Tubes is High!!?  (Read 750 times)
Offline GlennSpriggTopic starter
  • Medically retired Tech. Old School / re-learning !
« on: March 27, 2020, 11:35:57 am »
I unashamedly love all of "Mr. Carlson's" videos. (No-one speaks clearer).
Anyway, in one of his old posts, be was repairing an old but well known Guitar Amplifier, and replaced a 1st stage Tube. (Intermittent internal short from the heater filament to the surrounding cathode).  He talked a bit about the extreme vibrations inside the amp, due to the large internal speakers, that literally shake the shit out of the valves/tubes.
He said though, that he would normally love to use tubes labelled as "Made in USA", but they are not as strong internally.  Although a lot of 'modern' stuff from China may be cheap & nasty, he says that back in the days of Tube production, their manufacture of such copies were much more internally robust, and were  built to last!!  :-+
Diagonal of 1x1 square = Root-2. Ok.
Diagonal of 1x1x1 cube = Root-3 !!!  Beautiful !!
Offline jxjbsd
  • Country: cn
  • 喜欢电子技术的网络工程师
Re: Quality of old Chinese Valves/Tubes is High!!?
« Reply #1 on: March 27, 2020, 01:26:03 pm »
Generally speaking, the quality of electronic tubes produced in China in the 1960s-1980s is very stable.These electronic tubes are not of very high quality, but there is no problem in normal use.
Analog instruments can tell us what they know, digital instruments can tell us what they guess.
The following users thanked this post: GlennSprigg
« Reply #2 on: March 27, 2020, 02:02:21 pm »
Thanks.  Yea, he said he would not argue about 'Audiophile' quality, as it's always
in the 'ears' of the beholder...   :)
« Reply #3 on: March 27, 2020, 02:23:01 pm »
Just to add to that??...
What IS it that certain 'Audiophiles' try to explain about Quality??  It's a physical mechanical device with plates and a vacuum. Is it about the actual mechanical design/shape etc of the plates/parts within??  I can't get my head around that...  :o
Offline jxjbsd
  • Country: cn
  • 喜欢电子技术的网络工程师
« Reply #4 on: March 27, 2020, 03:03:49 pm »
 I belong to one of them 。 :-DD
but,I can't fully understand the behavior of these people.
In my opinion, the main differences of electronic tubes are: 1 material, 2 electrode mechanical accuracy, 3 vacuum degree
High quality electronic tubes are usually produced by these companies: GEC,MULLARD   STC Mazda、Brimar  ,Telefunken Valvo   From Britain and Germany  ,and  PHILIPS .
« Last Edit: March 27, 2020, 03:05:26 pm by jxjbsd »
« Reply #5 on: March 29, 2020, 01:19:39 pm »
Ok. However one aspect really confuses me. If physical design/shapes of plates etc is so important, what about the difference between directly & indirectly heated Cathodes??  Indirectly heated ones have a smooth geometric shape, but directly heated ones are just a spiraled heater element coil?  I would have thought the latter would be be more 'dirty' noise/quality wise?   :phew:
