Author Topic: Question abot a battery charger  (Read 1085 times)
Offline msuffidyTopic starter
« on: January 09, 2021, 09:52:07 pm »
I have a Sony BC-CS2A charger. Actually 2 of them. I can't find a manual for it and was wondering if it takes anywhere between 1 and 4 batteries at the same time. I have not tried mixing AA and AAAs and the same time. I am not sure they fit physically. This charger will error if it thinks the battery has an issue. I was wondering if in general battery chargers are designed to accept any number of batteries at the same time? In this schematic I can only find 2 places that look they are the application voltages in the upper right I think it is 5.4 and 2.1 volts.
« Last Edit: January 09, 2021, 10:02:59 pm by msuffidy »
Offline amyk
Re: Question abot a battery charger
« Reply #1 on: January 09, 2021, 11:05:11 pm »
Wow, that is roughly 10x more complicated than it needs to be...  but it looks like it has two channels.
Offline S. Petrukhin
  • Country: ru
« Reply #2 on: January 09, 2021, 11:43:42 pm »
The diagram clearly shows 2 separate channels of the current supplier, but one current sensor. Apparently, the charge occurs separately, and the current sensor is used as a common indicator.
Charging AA+AAA, I think, is quite possible. The principle of charging 1 battery or 2, connected in parallel - only a matter of choosing the current or time at constant current.
And sorry for my English.
  • Country: ru
« Reply #3 on: January 09, 2021, 11:44:58 pm »
Old school...  :)
« Reply #4 on: January 10, 2021, 01:48:00 am »
Thanks for the information. According to the diagram though are the 2 channels not connected together around on top of Q210? So perhaps basically 2 wires go to all the batteries in parallel? 2 channels would just double the current? Oh maybe it is a ground completed circuit under Q203 (negative battery terminal)? You probably wouldn't depict that with a ground symbol.
« Last Edit: January 10, 2021, 02:11:45 am by msuffidy »
  • Country: ru
« Reply #5 on: January 10, 2021, 11:04:25 am »
No. B1 has a connection to B2, B3 has a connection to B4, but B1, B2 have no connection to B3, B4. These are separate charge channels.
