The re-birth of the hobby is not the same as the re-enactment of the hobby. Let's face it: it will never be the same as when we did it a few decades back; one could argue it shouldn't be the same. There were no accessible microcontroller development systems when I enterd the hobby, so naturally we were using discrete components, more "analoguish" circuits etc. Today, many things we were doing discretely are better handled in a microcontroller. There will be always people that eventually will dig deeper into the components and analog circuitry, but that's no longer the entry point into the hobby.
I agree that people today starting should not look into the CMOS4000 and 74HCxxxx stuff, but for love sake, some do not even know what a transistor is why they need one to drive anything above 15mA with an I/O pin or even know the difference in configurations of an I/O pin between for instance pullup or floating when to choose one or the other. Not to mention an ADC which can have a lot of quircks when you don't use a correct filter and sample frequency for the input.
So to make an example to discuss I know this guy that has a model train hobby. He does not know anything about electronics (that is his own statement) but he buys ready Mitsubishi PLC's and I/O expanders and can control his entire trainsystem by programming it on a PC. He has a list of inputs (magnetic contact switches that close when a train passes by), he has outputs (relays, railroadswitches, lamps, trainID's to control movement). He does not know what a transistor does or how he should solder one, can not make a pcb, is not able to read schematics, does not know what is inside the PLC or even vaguely how it works). He is able to solder wires together, and then use the old tape to isolate it.
So tell me, this guy buys ready made modules, connects them, programs them: does he have an electronics hobby?
Another example: a lot of radio amateurs are excellent electronic hobbieists, but someone who only buys a ready made radio transceiver and talks with it all day, nothing else: does he have an electronics hobby?
You tell me your definition of when somebody has an electronics hobby.
