On the topic of Aluminized insulating sheet (as in the photo), a few years back (2010) there was a big government scandal in Australia.
A famous singer, Peter Garrett of Midnight Oil, had been elected to Australian federal parliament and became minister for the environment. He then oversaw a government scheme to subsidize improvements in home energy efficiency, by installing thermal insulation. Mostly in roofs.
Great, but the problem was he ignored advice that one form of insulation being used was unsafe. Metalized foil...
Something like 93 house fires and four deaths later, Peter Garrett took the blame.
The danger lay in installation methods. Installers would roll the stuff out in attics, then use staple guns to fix it down to the ceiling joists. But typically the electrical wiring in ceilings is also fixed to the joists, and a person on top of the insulation can't see if he's going to be stapling into wiring. The wires are only PVC insulated, not metal conduit.
So anyway, turns out the metalization IS electrically conductive.
