Peak oil has not been reached.
Neither has peak price.
i think its very close. allegedly, the oil coming out of the ground in certain places in the middle east is 90% water.. sea water they have pumped into the ground to push the oil out..
however,the following is the testimony from my late grandfather.
he worked as a test oil driller. they drilled hundreds of test wells and capped them, over a 20+ year time frame.
not one dry spot was found. provided, you were at least 5 miles offshore and drilled at least 5000* feet below the sea floor.
he did a lot of drilling off the coast of Europe, and from northern Alaska to the bottom of South America.
*might have been 2000 feet, i'm trying to recall.
if the price of oil gets to the point that nations start to lose it, there will be rogue oil wells guarded by mercs, all over the world. currently, most of the fields my grandfather explored are offlimits.
