Dev boards are/were exempt from that.
We never had to get the Altium boards certified for sale through Farnell or Digikey.
Maybe, but the marketing around Raspberry presents this board more like a tiny almost-ready-to-run 1080 mediaplayer without enclosure than as a dev board...
That and the intention to produce 10000's of them makes it an ordinary electronics device, subject to normal legislation.
Besides, a quick look at the EU EMC directive 2004/108/EC reveales only a few exceptions, and dev boards are not among those;
(c) radio equipment used by radio amateurs within the meaning of the Radio Regulations adopted in the framework of the Constitution and Convention of the ITU (2), unless the equipment is available commercially. Kits of components to be assembled by radio amateurs and commercial equipment modified by and for the use of radio amateurs are not regarded as commercially available equipment.
3. This Directive shall not apply to equipment the inherent nature of the physical characteristics of which is such that:
(a) it is incapable of generating or contributing to electromagnetic emissions which exceed a level allowing radio and telecommunication equipment and other equipment to operate as intended; and
(b) it will operate without unacceptable degradation in the presence of the electromagnetic disturbance normally consequent upon its intended use.Afaik you don't "get" a CE sign, you just put it there to affirm your device conforms to the standard. Or hope no one bothers to test it.
Yes, but the manufacturer is still responsible. In this case that means Farnell and RS, so they have good reason to demand formal testing for CE compliance. When another (EU-based) company produces or imports a product and puts a CE label on it, then it's their problem if lack of 'real' CE compliance becomes an issue. So no reason for Farnell or RS to worry too much about it.
