Author Topic: Reactance (impedance) quick reference chart  (Read 801 times)
Offline SomeoneTopic starter
    • send complaints here
« on: April 12, 2023, 04:56:55 am »
There have been various versions of these plots floating around even before the internet. Pretty self explanatory and convenient as a wall chart.
Download the pdf vector format below, it is not only vastly better quality but also a smaller file size.
The following users thanked this post: boB
Offline AndersJ
Re: Reactance (impedance) quick reference chart
« Reply #1 on: April 12, 2023, 05:14:17 am »
"It should work"
R.N.Naidoo
Offline jonpaul
    • IEEE Spectrum
« Reply #2 on: April 13, 2023, 02:19:03 am »
the reactance charts are very limited.
My 1960 Tektronix Circuit Computer slide rule is much more intuitive and versatile.
The Tek rep gave me two over the years,  beaten up but still in use.
Jon
An Internet Dinosaur...
Offline Tom45
« Reply #3 on: April 13, 2023, 03:33:34 am »
Reactance charts had been around a long time when this was published.
From Proceedings of the IRE ( Volume: 38, Issue: 12, December 1950):
Abstract:
The time-honored chart of reactance, frequency, inductance, and capacitance is extended in range, with added scales of susceptance, wavelength, and time constant. Simple geometric patterns are given which enable the chart to be used for the direct solution of various problems such as the bandwidth of a resonant circuit, some properties of a transmission line (wave impedance and delay), and half sections of the usual kinds of constant-k filters (low-pass, high-pass, band-pass).
I remember buying K&E Reactance graph paper at the university book store in the 1960s. I'm pretty sure I still have a few sheets. They are probably stored with my supply of carbon paper.
