Author Topic: reading wiring diagrams  (Read 433 times)
Offline hnjmklTopic starter
« on: August 12, 2020, 08:34:33 am »
I think the poor graphic definition of very old wiring diagrams is a felt problem, to repair a complex circuit you need to enlarge the sheet, but the definition gets even worse; I ask if there is a software able to remove the shadow on the sides of the graphic signs, alphanumeric characters, in short, make a straight line clean and defined, I tried with gimp but no filter works, I try to post a small portion of a circuit.
Online TimFox
Re: reading wiring diagrams
« Reply #1 on: August 12, 2020, 01:18:10 pm »
A photo-imaging software package (I use Corel Paintshop) has spatial filters that might help.  Paintshop has "high-pass sharpen" that works on architectural photos to do a similar effect.
