Author Topic: Real Engineering: Insane Engineering of the F-35B.  (Read 2997 times)
Online 2N3055
  • Country: hr
Re: Real Engineering: Insane Engineering of the F-35B.
« Reply #25 on: January 29, 2023, 06:20:09 pm »
Frankly, I do not understand why the pilots are still sitting there in the F35.. :)
You can fly it from your home-office..
Its easy to do that when nobody is trying to stop you. It turns out to be very hard to keep communication with an air vehicle rock solid when people are trying to stop you. Drones have been working great in situations where the enemy is not very sophisticated. When they are, perhaps its a less effective approach. The approach being sought for next generation pilotless fighters is to make them sufficiently smart that they can act on their own for much of the time, doing more sophisticated things than just avoiding a crash when there is no real time input from the comms links.
Even F18s have direct laser communication with satellites. The only way to block that is with an object in between. Or a cloud, but that's not the point. Why wouldn't have the F35 a pilot in it? I think pilotless aircraft has a place, and they have been sending these aircrafts in when it was cheaper, or there is no air superiority but loosing them is no big deal. In which way would a pilotless aircraft be better? It can pull more Gs. Otherwise that's it, having the pilot is not a drawback. And pulling Gs is not what you do with this aircraft. You fly in, launch some rockets to targets at 30km range. Nobody is shooting at your plane, they don't even know you are there unless you turn on the transponder. There is no dogfight, since it's not the 70s anymore.
Not even with a SU-57, since the radar signature of it is so bad, they don't allow them to fly against MIG-29s, or to fly into contested airspace. in fear that a simple manpads will shoot it down. It has similar radar signature than a F-18 except from the front. And then it comes the: "comrade we don't have rokets for the internal bay we fly external yes?" part.
Keyword: latency...
Dr. Richard W. Hamming
Online coppice
« Reply #26 on: January 29, 2023, 06:47:13 pm »
Current fighters are built around the size and limitations of a human being. The larger ones are also designed around the size of radar that will be in their nose, but pilotless aircraft might operate in swarms with the radar function offloaded. Get rid of the pilot and you can make cheaper, lighter, stealthier planes that work at stresses no human could cope with.
Offline Infraviolet
« Reply #27 on: January 29, 2023, 06:48:12 pm »
So, post #25, ChatGPT has clearly been fed on material which warns of the F35's problems, hence the Su57's victory in its composition... but it forgot that with the state of Russian military logistics today the Su57 would probably have run out of fuel before it could get off the runway.
The following users thanked this post: tom66
Offline shapirus
  • Country: ua
« Reply #28 on: January 29, 2023, 06:55:50 pm »
its still designed to kill people.
which, under certain circumstances, is a good and necessary thing, which, being a weapon, a well-designed military aircraft is required to do with high effectiveness.
Offline jfiresto
« Reply #29 on: January 29, 2023, 07:24:09 pm »
The actual state or the imagined state? There are two quite different wars being fought. How does it choose?
-John
Offline tszaboo
« Reply #30 on: January 29, 2023, 07:45:24 pm »
It's a surprisingly cheap aircraft, even if it doesn't look that way. It's cheaper than upgrading the F16s and 18s to today's standard. It's cheaper than it would be to make those today alone, excluding the upgrades. And then you have a plane without integrated systems.
And it's designed to replace half a dozen planes, no wonder it has to be versatile. It's like the MBT, which replaced every other tank on the field. It's cheaper to have just one type. And for other roles there are UAVs, AC130s and AWACs.
Besides, I'm like 90% sure it could fly without pilot, either already or with future upgrades.
Online langwadt
« Reply #31 on: January 29, 2023, 08:22:45 pm »
there's also a bunch of safety and redundancy you can skip if you don't have to protect human "cargo"
Online SiliconWizard
« Reply #32 on: January 29, 2023, 08:57:27 pm »
:palm: How did a tech engineering forum post look at a technical marvel generate a first response being political in nature.
Because the F35 is not an engineering program, but a political program? Every design decision was based on its political impact.
While military programs are political by nature, and some decisions for the F-35 were undeniably questionable, the thread is about the engineering side of it, and however politically you look at it, you can't deny the insane engineering behind it.
