Some things I noticed about the 1251A after opening it up and checking it out:
* It was nice that Agilent includes lots of accessories that Fluke don't: Carrying case (with nice pockets as mentioned above), test leads with many attachments. Also, the USB cable doesn't cost as much as a mid-range DMM (Yes, Fluke, I'm talking to YOU!
). That said, while the test leads with attachments are versatile, they feel a little chintzy compared to Fluke/Pomona leads. Something about the plastic (and the attachment insulation such as on the alligator clips) seems, er, light and plasticky. Fluke leads feel more substantial.
* The display update is out of this world! I actually wouldn't mind slowing it down a bit. I'm not sure the fast update really is providing me any benefit.
* I haven't tried data logging, but I know that with the Fluke 289 I always use the trend plot function, so I think that logging without graphics will be a letdown. It's a nice size for a logging meter; the Fluke is a brick.
* The display is a little bit cluttered, but not too bad, and I much prefer the 7-segment LCD for routine readings to the "smooth" digits of the 289. I don't know why Fluke doesn't have an option to simulate a 7-segment display for doing basic measurements...
* I like that the meter turns on with the rotary knob, rather than a power button. I know others feel differently. Power-on is very quick. The 289 is a dog on startup. One great feature is that there is a OFF position on both ends of the dial. Very clever! The switch has an excellent feel to it.
* Continuity test is painfully slow; the trick of using the diode setting is a good one, Dave! Also, the beep is on the intermittent side. I am not sure it's latched. Even my old Fluke 8060A is far better for continuity.
* On the other hand: Voltage readings are lightning quick!
* A real calibration record included! Mine was sitting around a long time: Calibration was in November 2008, only good until April 2009. On the positive side, the actual data is very impressive. Most of the readings were 3-4X better than spec, some even 10X better than spec!
* No Golden Power battery
No battery rattling, either.
As many others have said, at it's original price, I think you'd do better with a Fluke 87V unless you needed logging. It was shown elsewhere on EEVblog that this is a rebadged Escort. Anyone know what that Escort used to cost? At the giveaway price that Grainger had, it is definitely worth the money.
