Author Topic: What DCDC VRegs have a constant current limit feature? Its hard to search for it  (Read 720 times)
Offline PsiTopic starter
I'm looking for a little monolithic DCDC VReg chip but I'm having trouble finding an all-in-one IC solution that fits my requirements.
Anyone know a chip that has the following specs?
- My main requirement, (the one causing issues), is a built-in constant current regulation feature.
I want it do CC mode at around 3A with the output going down to a few volts in CC mode.
I have found some chips that have CC mode, but they sense current in the ground line. For my application input and output ground must be common.
- Built-in switching mosfet
- Input 12/24v system, so needs to be spec'ed to run up to 32V
- Output regulated to 15V (if Vin high enough)
- Step-down (or could be step-up/down)
- Ideally automotive rated spec
- Price per chip can be high-ish, if needed. $8 each at 100pcs is not out of the question.
Any recommendations welcome.
« Last Edit: November 02, 2020, 10:58:18 am by Psi »
Offline daqq
  • Country: sk
    • My site
Could this work?
https://www.analog.com/media/en/technical-documentation/data-sheets/3477fd.pdf
edit: See page 14 for higher voltage operation.
« Last Edit: November 02, 2020, 10:51:43 am by daqq »
Could this work?
Sadly the circuit on page 14 that allows higher voltage operation removes the common ground between input and output.
Offline tom66
You could implement this function by driving the FB line of many conventional DC-DC converters with an external op-amp.  That op-amp could use a high side current sensor (e.g. Zetex ZXCT10xx) to monitor output current.  If you use a diode to OR your feedback signal, then you could have CV/CC operation.
I appreciate this is more complex than an off-the-shelf solution but it may end up giving you the most availability.
yes, this is my fallback option.
I just really want something that's ready to go and am willing to pay a bit more for it.
For this project being able to take the example schematic from the datasheet and know it will work first time will be a big time saver. It will require less testing and validation.
« Last Edit: November 02, 2020, 11:07:45 am by Psi »
