Hi folks, is any refrigeration expert here, or maybe just someone with better searching skills.
I'm trying to find out how are electronic expansion valves controlled in systems without pressure sensors when you have only temperature sensors.
With a pressure sensor, it is simple, you can calculate superheat and just open the valve more to decrease it.
But cannot find how they do it from temperature only, do they estimate pressure based on evaporator inlet temperature?
