Author Topic: Removing the protective varnish from the PCB  (Read 1740 times)
Offline frantisekTopic starter
  • Country: cz
« on: September 15, 2021, 01:25:06 pm »
Can anyone please advise how to remove about epoxy protective varnish from PCBs of Russian measuring instruments? Thanks!
Offline magic
Re: Removing the protective varnish from the PCB
« Reply #1 on: September 15, 2021, 07:11:49 pm »
Ordinary soldermask or conformal coating? Neither is very easy tbh.
What are you trying to achieve?
Offline ogden
  • Country: lv
« Reply #2 on: September 15, 2021, 08:33:35 pm »
Further reading: https://www.vaniman.com/ultimate-conformal-coating-removal-guide/. In short: epoxy conformal coating is worst case, you need set of preheating + ESD-safe microblasting equipment, right consumables.
  • Country: cz
« Reply #3 on: October 04, 2023, 04:33:32 pm »
Now I know how to do it without preheating!!
Offline p.larner
« Reply #4 on: October 10, 2023, 12:40:48 pm »
paint stripper works well+ a brush under hot running water .
